EAPS.Rx8021QtagInv
Description
EAPS PDU being dropped because the vlanTypeLength field in the ethernet header does not match the default ethernet value for 8021Q Tag.
Remedy
Possible programming error or misconfiguration of VMANs, QinQ, Mac-In-Mac. Check if an ACL may have modified the vlanTypeLength field.
Severity
Warning
Message Text
%slotPort%, %vlan% - VlanTypeLength (%vlanTypeLen%) not equal to default Ethernet value (%defaultEthVal%)
Message Parameters
Name Type
slotPort SlotPort
vlan VLAN
vlanTypeLen uInt
defaultEthVal uInt
